dclark1946
Jun 19, 2016Explorer
Lynnmor wrote:
You really need to forget about that brand of antenna. As you know, the antenna is omnidirectional, and will give poor performance with the TV as well. It was installed because it was the cheapest thing that could be found and it looked like a real antenna.
Yep I am aware that the installed TV antenna is marginal and not comparable to the Winegard Sensar antenna. The factory and my dealer declined to install the Winegard antenna so I will need to find another RV service center to change that out. My thought was to initially either change to the other model TV antenna that supports AM but requires another coax line to be run above the ceiling (no idea how big a problem that will be) or add a conventional whip antenna to fix the AM reception issue. I think the whip antenna install may be simpler because it can be installed on the roof right over the receiver and the coax line be brought down in a non functional cabinet.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
