myredracer
Jun 19, 2016Explorer II
dclark1946 wrote:
My thought was to initially either change to the other model TV antenna that supports AM but requires another coax line to be run above the ceiling (no idea how big a problem that will be) or add a conventional whip antenna to fix the AM reception issue.
Running wiring/cables through a ceiling and inside interior walls is pretty straightforward. I've also done it in the same model of Spree with romex, coax, HDMI & low voltage wiring from the front to the rear of our Spree and can tell you exactly how and where to run it. Let me know if I can help you.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
