dclark1946
Jun 19, 2016Explorer
myredracer wrote:dclark1946 wrote:
My thought was to initially either change to the other model TV antenna that supports AM but requires another coax line to be run above the ceiling (no idea how big a problem that will be) or add a conventional whip antenna to fix the AM reception issue.
Running wiring/cables through a ceiling and inside interior walls is pretty straightforward. I've also done it in the same model of Spree with romex, coax, HDMI & low voltage wiring from the front to the rear of our Spree and can tell you exactly how and where to run it. Let me know if I can help you.
Thanks for the offer on routing cables in the space between the ceiling and the roof. It seems to me it would be tricky to get the cable through the insulation that I think is installed after the wiring is routed. I guess you could attach two new coax cables to the existing coax and pull the original coax out.
I will PM you to discuss some more.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 13, 2026
