dclark1946's avatar
dclark1946
No AM Reception on New Trailer
I am working out issues on our new trailer. On the initial camp out I tried out the new entertainment system and everything seemed to be OK except no AM reception when you tuned through the whole band. Tried that again when we got home in the DFW area still nothing at all on the AM band. The trailer has a new to me Continuus fixed External HDTV RV antenna model CA1500 which I suspect is the issue since it lists both video and FM frequency bands but no AM band capability . Continuus also makes a similar looking CA2500 model which lists a wider TV band, FM and AM frequencies. The CA2500 is listed with 4 RF Jacks but the CA1500 model lists only 2 RF jacks. The receiver is a Jensen AWM 968 Mobil Audio System with what appears to have only one automotive type antenna jack. My first thought was to switch to the CA2500 model but not sure about 4RF Jacks if the AM is by itself or combined with the FM like it is in an automotive radio antenna.
At the moment, it appears the KZ wrote off AM reception by using a lower cost antenna. Our older KZ had a small whip antenna feeding a Jensen Automotive radio/DVD player and that worked well for both AM and FM.
Anyone familiar with the Continuus RV antenns?
  • Lynnmor wrote:
    I had no idea that KZ stooped to that level. You have a worthless antenna, and after looking at other antennas from that company, I wouldn't want any of them.
    You need to install a real TV antenna like a Winegard batwing, and a real AM/FM whip antenna. Only then can you see if the low end Jensen will meet your needs.
    Yes I was concerned about the TV antenna when we looked at another new Spree before we ordered ours. At that time I was not aware that the whip antenna had been eliminated. We had the Winegard Sensar antenna on our old trailer and I miss that too. I tried to get the factory to install the better antenna but they would not.
    I think the Jensen system will work for us if it holds up like the simpler Jensen we had in our previous trailer.
  • I had no idea that KZ stooped to that level. You have a worthless antenna, and after looking at other antennas from that company, I wouldn't want any of them.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 28, 2025
