drsteve
May 26, 2020Explorer
ajriding wrote:
A multi-meter will only tell you voltage, so checking all connections will not tell you if it is getting a good flow of that 12 volts, which is also called amps.
Truth. The way around this is to use a test lamp rather than a voltmeter. If there's not enough current, the lamp will show it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
