peteandpatty01
May 06, 2014Explorer
no charging voltage
Have a four winds hurricane motorhome. Had to replace my 12V house batteries (two in parallel). I checked the voltage at the cables that attach to the batteries and have 0 volts. I expected about 13 volts DC. This would be coming from the converter to keep the batteries charged. I checked the out put of the converter and have 13.6 volts DC. All the 12 volt lights work and the engine battery is fully charged after sitting all winter hooked to shore power. So my questions:
Am I correct in expecting 12 to 13 volts at the cable ends that attach to the house batteries?
Is the circuit from the converter to the batteries fused?
If fused where would it be located?
Thanks for any help you folks are great.
Peter
Peter
