EV2
Oct 16, 2016Explorer
Dennis M M wrote:
It's a piece of cake!
7. finally push open the check valve on the city water hook-up and let pink stuff flow. Don't look into the valve while you are doing this! (Don't ask)
Others will jump in if I missed anything!
Doing this with pump on or pressure on line is a recipe for dislodging the internal o-ring in the check valve requiring repair or replacement of a leaking valve. Always let all of the pressure out at a faucet with the pump off. Then carefully depress and have someone run the pump for a short duration. No surprise this way and no damage.
