Positive exiting inverter was loose but at first I wasn't concerned but loose wire kept coming up in responses here so I finally really tighten clamp on wire & much to my surprise I had 12 volt power ...
Your prior thread indicated your converter was putting out 13.6 volts but your battery wasn't charging. That usually means that you have a fuse/solenoid or other issue between the battery and the converter - if so replacing the converter won't fix your problem.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
