Old-Biscuit
May 07, 2016Explorer III
You have good 12V DC as evidenced by the sparking sound.......that means 12V DC fuse is good and that the 12V DC set of t-stats are good.
Gas valve solenoids get 12V DC for 6-8 seconds while Spark Electrode is firing.
IF no Main Flame occurs (and is proven) during that time the DC is dropped to gas valve.
Several attempts can be necessary if propane has not been used recently.
But you need to check a couple things.
Do you hear the gas valve solenoids CLICK.......should be able to feel them CLICK when energized by DC?
You can test by measuring DC Voltage (Red to Black)
Can you SMELL any propane when Spark Electrode when it is firing?
Main gas orifice could be obstructed (Need to remove burner tube then unscrew orifice and soak in alcohol to clean----then blow out with air)
If gas is flowing then Spark Electrode although sparking may NOT be positioned correctly...1/8" gap and directly in path of gas flow
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
