Harvard
May 07, 2016Explorer
amdriven2liv wrote:
Yes it is a Suburban. Will cleaning it help the solenoid?
No, cleaning will not help. When the solenoid coil goes open it must be replaced. You might be able to replace just the coil if you can find one in a RV scrap yard. Otherwise the whole valve assembly will be the only part you can buy at an RV parts store.
Get a friend who knows how to use an Ohm Meter confirm a coil is open before you proceed down this path.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
