toytacoma8's avatar
toytacoma8
No gas to stove only
I have a 2015 Jayco with an Atwood stove. One day it worked and the next day there was no gas to the stove top or oven. All other appliances work fine on gas. I see a regulator in the stove top under the top portion. Do these go bad? Any other obvious places to look before I start digging in?
Thanks
Andy
  • Pulled the hose off the regulator and gas flowed out of it. Disconnected the regulator from the stove and put it back on the hose and no gas came out. Looks like I found the culprit?
    55 bucks on Amazon for this little guy.
    GRH60. LpG 10" WC
  • toytacoma8 wrote:
    I'll give that a try. It's bot in a slide out so I can't imagine the hose got pinched. We were on the way home from a 2 week road trip where it worked fine. Luckily it waited until the drive home to stop working
    Is the supply hose to the stove top Rubber or Copper? Let us know if the LP flow test I mentioned spews LP or not. Doug
  • Cummins12V98 wrote:
    Does the cooktop have a lid that is fixed at a hinge point? If so the switch may be faulty or came loose.
    Please explain this comment. I have 44 years as an RV tech and have never seen a RV cooktop cover that has a "safety" switch. Kind of makes NO sense. To light a cook top burner you have to lift the bi fold cover anyway. Doug
  • Does the cooktop have a lid that is fixed at a hinge point? If so the switch may be faulty or came loose.
  • I'll give that a try. It's bot in a slide out so I can't imagine the hose got pinched. We were on the way home from a 2 week road trip where it worked fine. Luckily it waited until the drive home to stop working
  • Is the stove in a slide out? If so, odds are the rubber LP line is pinched. The regulator you see drops the Supply from normal 11.5 inch water column to 10 inches. They rarely fail. They do leak sometimes but rarely fail to deliver LP. What you need to do is, TURN OFF LP AT TANK. Disconnect the LP line from the regulator on the stove. Then while holding the LP line have someone turn on the LP tank. IF the LP spews out turn off the tank. IF NOT, the pinched hose is the problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,237 PostsLatest Activity: Apr 23, 2025
