I have a 2013 Fleetwood Excursion RV and was recently camping when the AC and heat woul not come on. I checked the gas line, breakers and turned it off for 5 to 10 minutes. When I turned it back on th...
Don't know much about how the MH's work but all the things you describe is BATTERY RELATED. Need to measure battery DC VOLTAGE at the terminals with the DC disabled going to your appliances and lightning. They should read 12.6-7VDC if fully charged and will read 13.6VDC if you are connected to the on-board converter/charger unit and plugged into shore power or running off your generator.
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
