I have a 2013 Fleetwood Excursion RV and was recently camping when the AC and heat woul not come on. I checked the gas line, breakers and turned it off for 5 to 10 minutes. When I turned it back on th...
If the battery is at 12.6v at the battery posts when not charging, and the lights are dim, then you have a wiring problem. Since the lights got brighter when you "turned it back on" it seems like your converter is working. Maybe your battery is simply discharged. Depending on your converter it can take a long time to recharge your batteries.
Just noticed the date on your post, so maybe you have solved the problem. How about some feedback???
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
