Camping this weekend and it’s a bit chilly... went to turn the heat on and nothing! The fan kicks on for a minute or two and then shuts off. All the other gas fixtures are working properly. I crack th...
Stink bugs. Probably dead now. Flippin' things get in everywhere, and one crawling into the burner tube of your furnace, water heater, grill, or other propane appliance will screw up the burn and result in just this problem. On the one hand, pulling the burner assembly out and blowing the bug(s) out is a cheap fix. On the other hand, it's a pain in the neck for sure. So before you fuss about the other issues above, look for stink bugs in the burner.
