pa_bell
Nov 06, 2019Explorer
Yes, it has been used for 5 winters in Florida. Last spring before we left the electric would get too hot and come out the pressure relief valve. The LP worked fine. I took the switches from the wall and see 12V passing through both LP and electric with a multimeter. I do not see 12 V at either t-stat. I cleaned out the LP tube and orifice.
The battery is at 12.8. I had the generator running to provide shore power.
I am running out of time since the RV in a storage lot and I am using water from fresh tank. Tomorrow night will be 16 degrees and I think I should drain that tank and winterize.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
