dougrainer
Jun 21, 2013Nomad
Open the pressure (pop off) valve when the water is NOT heated and see how it flows out of that valve. If you have the same problem, then your input to the water heater is screwed up. IF water flows out of the Pop Off valve good then your upper exit fitting has a problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
