Dutch_12078
Sep 28, 2014Explorer III
If you have an outside shower ("dog wash"), make sure both valves are turned off, not just the control on the shower head. As with an incorrect bypass setting, the open faucets can allow cold water to run into the hot line when the higher cold pressure with the pump on over powers the hot pressure. With the pump off, the lower pressure may allow the system to work near normally.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
