jfdavis17's avatar
jfdavis17
No hot water when water pump is on.
I have a 2013 Winnebago 27rbds travel trailer, the hot water will not work while the water pump is on. If I turn on the water pump and let water pressure build in pipes and then turn it off the hot water will work until all water pressure is gone, once I turn the pump on the water will turn cold until I turn it back off at which point it will go back to hot until the pressure is gone again. The camper was brought straight from the dealership to a remote location where it is now, I have never had it hooked up to a municipal water system so I do not know how it would behave on one. Any help would be appreciated.
  • Sounds like your water heater bypass valves may not be set correctly. If you have 3 valves, the 2 in the pipes into the heater should be on, the one between the hot and cold water pipes should be off.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
