I have been getting luke warm water at best recently and now am getting none. I have tried the electric and the gas and now the gas will not even work. Any ideas?
Can you hear the water heater burner while on gas? Check they bypass valves to make sure they are in the correct position and make sure the air is purged from the tank using the pressure relief valve. if you have an outside shower, make sure it's fully off at the valves and not just the head button.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
