ricks99's avatar
ricks99
No hot water
I have an Atwood GC6AA water heater. I have selected the ELECTRIC switch, but not getting any hot water (I waited an hour). I opened the water heater vent, and there is a single amber light and a slight humming sound. After about 5 minutes, the "DSI-FLT" light on the control panel lights up. I've tried using propane, but same result. Any ideas?
Thanks,
-R
  • Ok, it is all Greek to me.
    Is there some basic troublehooting a complete novice can try I've got a hammer with me, and can try hitting it. :)
    I checked the 5Amp fuse in the water heater and it appears fine...that's the level of my abilities
    Thanks!
  • 2017 year combo gas/electric Atwood uses a common DC source (fused) to both electric & gas on-off switches
    From the switch DC goes to circuit bd...White wire/Electric & Orange wire/gas
    Then electric & gas use same/common components....circuit bd, thermal fuse, t-stat, ECO
    Electric uses DC to trigger the electric via DC/AC Relay
    So need to follow DC Voltage thru circuits to find where it isn't...
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
