https://i.imgur.com/bQulQ6Z.jpg This is our water heater in our camper. We're not getting any hot water out of it whatsoever. The "Water Heater" switch on the switchboard lights up, so it seems t...
That "clear plastic thing" is the thermal cut out, sort of an over temp fuse. It's easy to test just by unhooking the cut out from the thermostat terminal and the quick connect wire at the other end. Connect the wire directly to the thermostat terminal and try the heater. If it works, the cut out is bad. If it still doesn't work, the problem is elsewhere.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
