tdcoop616ExplorerSep 19, 2019No hot waterI have a 2016 Vengeance 39R12. When we have the hot water bypass valve set to normal, no water comes out when we turn on the hot water. There is no check valve coming out of the hot side of the hot ...Show More
wa8yxmExplorer IIISep 20, 2019Key phrases"We have THE hot water valve set to Normal""There is no check valve..."IF you have a single valve bypass system there **MUST** Be a check valve and that valve is your problem.If you have a TWO valve system the check is not necessary but you must turn the other valveI have a 3 valve system, also no check valve but the all 3 valves need to be properly set for it to work.But if you have a single valve. as your post implies THERE MUST be a check valve.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
Related ContentNo flow from hot water tank Nautilus P1 systemHot water heater question .....Hot water problemHot Water ReplacementHot water element
