Had a similar experience last weekend while out camping. Friday the hot water worked fine, Saturday no hot water. Had good flow (full tanks), 120 AC and full LP tank. Checked the breakers and fuses even pushed on the Reset buttons on the water heater.... still nothing. :h
Then my buddy bent down a little lower than I could and said hey whats this switch do? Back down low is a simple ON/OFF black switch which for reasons known only to the RV God's had tripped itself like a breaker. There is no mention of this switch in the owners manual but I assume it is just to enable you to manually shut the water heater off.
Flipped it to on and presto, all the hot water we could ever want. :S
