- skipncharExplorerDo you mean you get no water from hot faucet or the water is not hot?
- Old-BiscuitExplorer IIIYou get HOT flow when on city water connection but no Hot water flow when on pump??
Do you get cold water flow when on pump?
Do you have the 'water valves' set correctly for pump?
City water and pump discharge are connected and feed the same plumbing system.
So if city water works then pump should work also....provided valving is correct and pump works.
Same WH so same Hot water.
More info on what is NOT happening......no hot water, no hot water flow, no hot/cold water flow etc. - 1492ModeratorMoved from Forum Technical Support
- tenbearExplorerIs this something that has recently changed, or has it always been this way? Has any work been done on the RV if it is a recent change?
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
