wa8yxm
Aug 29, 2016Explorer III
The recommended charging voltage is different for AGM's but only by a tiny amount.. Few converters are that well regulated and in fact how hot it is makes a difference as well and few are compensated for temp.. So the difference is too small to matter.
The big difference is something called Acceptance.. Some AGM's can accept a re-charge (Bulk mode) that is very, very, very fast, as much as 10x what a Flooded wet can take... (Specifically Lifelines are like this). Others the recommended max is about the same as Flooded so again, for the most part no differnece.
OPTIMA (A special case of AGM) has less capacity per cubic foot Recommend against unless you are in "Rough Service" (IE: Wave Runner, 4-Runner)
I have found AGM's do not, as is often preached, last longer... In fact I do not see how a "Sealed" type (Valve Regulated) can outlast a properly maintained flooded wet.. But they are nice if you have access issues.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
