MrWizard
Aug 30, 2016Moderator
Almot
according to Mexi's previous posts
charge at 14.4 until charge rate drops below 1% of ampHr capacity
aka 500ampHr bank charge at 14.4 until amps in are 5amps or less
then turn off charger until next charge cycle
If possible charging current of a bank with an SOC of 70% or less
should be c/5 aka 20% of capacity, in this example try for a starting rate of 100amps end at 5amps
this negates the need of the 'equalization conditioning charge'
my PD70 will only do about 12% of my 675 ampHr bank
but since i need the genny for the A/C i am charging until full
this winter, the charging profile will change some, but so will my overnight use
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
