relaxin wrote:
hello fellow campers.
with some parks up here now banning generators, some in designated areas and some outright, and the fact that getting a electric serviced site is getting harder and harder during peak season, has anyone tried these new power supplies
back up power
theres this company and another
other company
keep in mind prices are in CA dollars, they are probably 1/4 the price in the US.
Just wondering if this is a possible solution to running a generator, it may not run the A/C very long but up here we can get by without that and the microwave, and run the fridge on propane, just need the lights and electronics pumps, fans and maybe some music for a 3 day weekend. perhaps the tv for a movie on a rainy day.
if you have one let me know how it works for you.
These are nothing more than an expensive battery with inverter in a box.
Calling them a "generator" is laughable at best as when you discharge them you must eventually recharge them. Each time you discharge/recharge the batteries lose capacity.
Storing them can also be problematic at best, batteries of any type must be stored properly, Lithium batteries are no exception to this. Failing to store properly will result in a unusable battery in short order.
BATTERY UNIVERSITY says this..
Battery SoC is reflected in OCV. Lithium manganese oxide reads 3.82V at 40% SoC (25°C), and about 3.70V at 30% (shipping requirement). Temperature and previous charge and discharge activities affect the reading. Allow the battery to rest for 90 minutes before taking the reading.
Li-ion cannot dip below 2V/cell for any length of time. Copper shunts form inside the cells that can lead to elevated self-discharge or a partial electrical short. (See BU-802b: Elevated Self-discharge) If recharged, the cells might become unstable, causing excessive heat or showing other anomalies. Li-ion batteries that have been under stress may function normally but are more sensitive to mechanical abuse. Liability for incorrect handling should go to the user and not the battery manufacturer."
Tektronix has a good guide on Lithium battery maintenance and storage..
HERE"Lithium-Ion Battery Maintenance Guidelines
Lithium-Ion rechargeable batteries require routine maintenance and care in their use and handling. Read and follow the guidelines in this document to safely use Lithium-Ion batteries and achieve the maximum battery life span.
Overview
Do not leave batteries unused for extended periods of time, either in the product or in storage. When a battery has been unused for 6 months, check the charge status and charge or dispose of the battery as appropriate.
The typical estimated life of a Lithium-Ion battery is about two to three years or 300 to 500 charge cycles, whichever occurs first. One charge cycle is a period of use from fully charged, to fully discharged, and fully recharged again. Use a two to three year life expectancy for batteries that do not run through complete
charge cycles.
Rechargeable Lithium-Ion batteries have a limited life and will gradually lose their capacity to hold a charge. This loss of capacity (aging) is irreversible. As the battery loses capacity, the length of time it will power the product (run time) decreases.
Lithium-Ion batteries continue to slowly discharge (self-discharge) when not in use or while in storage. Routinely check the battery’s charge status. The product user manual typically includes information on how to check battery status, as well as battery charging instructions"To put this a bit more into perspective, batteries of any type whether being used or being stored lose capacity and life.
Contrast tho generators which as long as you check and change the oil at recommended intervals and you do not leave gas sit in the carb while stored can be used and stored for many, many yrs without loss in capacity..
Come back in 5 yrs, 10 yrs, 15 yrs, 20 yrs and give a report on how well your purchase of that "power station" or "noiseless generator" has gone..
So far, my noisy generators have given me 20+ yrs of service and I have even added a 30+ yr old gen to my stock which sat abused with water in the fuel tank for so long that the tank was loaded with rust right up to the top of the tank.. Cleaned the rust out of tank and carb added some fresh gas and engine came to life after two pulls..
Would love to see a 30yr old Lithium based power pack with inverter come back to life with full capacity after being stored for 30yrs with no periodic charges..
