campingwiththor's avatar
Apr 27, 2018
No outlet power on street side - Gfci ok??? What’s up?
My truck camper has an intermittent power out issue-
that may be a short or caused by rain???
All was fine then post big rain all 3 interior
(Bed area, dinette & bathroom) Outlets
Turned off.
The microwave outlet is aok. The kitchen gfci
( only gfci in camper) is working & the exterior
City side outlets work.
This is a 2003 Bigfoot 2500 truck camper.
Any ideas on how I might trouble shoot appreciated.
CWT
  • Dutch_12078 wrote:
    Check those outlets carefully again, especially the one in the bathroom. That one is typically a GFCI. Also check your breaker panel, the breaker serving those outlets could also be a GFCI.
    Only one gfci in camper... it’s in kitchen
    area... when it’s very wet & rainy it
    Pops off often... otherwise aok.
  • Your positive you have only one GFCI? Start at the breakers, flip them off and back on. Then start at the first dead outlet and open it up. Using your VOM check for voltage. Yea? Move on. Nay, start looking for loose wire. My guess your going to find a loose push on connection. If so, replace with a regular screw terminal outlet.
  • Check those outlets carefully again, especially the one in the bathroom. That one is typically a GFCI. Also check your breaker panel, the breaker serving those outlets could also be a GFCI.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
