Gjac
Jun 21, 2021Explorer III
Burk12 wrote:That is what I had to do and when I traced the positive wire twenty feet to the house battery I found the cable lose inside the terminal. Cleaned the corrosion off and re crimped and all was well again. If you checked the circuit breakers and they are good the next logical thing to look at is the positive wire. The other thing you can do is jump your car battery to the starter and if it starts you found the problem. You may have a braided ground wire going to the frame that you can check and clean also.
None of the 3 switches work (including the one locally)
No voltage at the starter
I'll keep looking for more fuses and breakers.
I'm at the point of crawling underneath the motorhome and backtracking the power cable that feeds the generator + voltage.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
