- MEXICOWANDERERExplorerI sure like the wave form of the old 18-turn 6.5NH
Volts per Hz, but with a decent governor their reliability is had to beat. Reconnect 30 amperes 240, or 60 amperes 120vac.
Big generators are expensive to convert to inverter. Components like diamonds increase n price to the square of the size. - mlts22Explorer IIBecause it is "analog", where the wave comes from the crankshaft spinning at 3600 RPM (1800 RPM for older, four pole models), it is a pure analog sine wave in that sense.
Now, how clean it is, especially under load, is a different story. There have been youtube videos testing this, so I'd probably go look there, but Onans are decent, and produce clean power for pretty much anything. - jhilleyExplorerIt is pure sine wave and not an inverter type generator
- road-runnerExplorer IIIIt is not an inverter generator, and is therefore in theory PSW. In practice its waveform isn't nearly as pretty as from a good PSW inverter generator, but it definitely does its job well.
