DickandVicki's avatar
DickandVicki
No trailer brakes
DW and I are spending the summer in Olathe, CO - can't stand the humidity in FL! When I was preparing to unhook here, I wanted to move my Curt slider hitch to the rear or maneuver position, so I positioned to slide lever on the hitch, got in the truck, squeezed the brake controller levers (as I've done many times before), put the truck in gear and moved forward - only problem was, so did the trailer! Ended up putting wheel chocks fore and aft to block 5th wheel from moving. So...realized I had come down the 11K foot drop from Monarch Pass (Rt. 50) w/out trailer brakes on the way here - thank the good Lord for His protection! So yesterday, I began to investigate my dilemma. I sanded the contacts in both the plug and truck receptacle (which both looked good to begin with) then plugged the trailer to the truck. Started the truck and had DW try both the controller levers and brake pedal while I had my hands on the trailer brake drums, but felt nothing. Today I got my multimeter out, turned the truck on, and had wife turn try signals, running lights, etc. on and all was well. So I had her squeeze the controller levers and got voltage, but when she released them and applied the brake pedal, no voltage. There is a 30 amp fuse for the trailer brakes in my engine compartment which I pulled and checked, and it was good. Any ideas out there? Am I right in thinking if all is well, I should feel SOMETHING on the brake drums when brakes are applied?
  • Brake controllers are simple. Ground/HOT 12 volt/FEED to trailer plug/BRAKE PEDAL brake light wire. So, you probably have NO power to the controller when pushing the Brake Pedal. The RED wire goes to the cold side of the Brake Pedal light switch. So, check for 12 volts on the RED wire when you push the brake pedal. Doug
  • Some integrated controllers do little or nothing below 11 MPH, see your owners manual.
    Check your ohm reading on the trailer between the brake pin and the ground pin, should be about 1 ohm. Test
  • What truck do you have? Is it newer with a built in brake controller?
  • If you can't feel anything take a compass and put it next to the wheel you want to test when the magnets on the brakes get power from the brake pedal the compass needle will move.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
