landyacht318
Feb 08, 2017Explorer
Try the silverstone fm 121
120MM and variable speed adjustable via a small potentiometer.
110CFM on high at about 0.4 amps, about 32cfm on low at about 0.09amps.
Dial a speed, dial a noise level.
If you want more of a set it and forget it fan, then try an industrial Noctua.
https://www.amazon.com/Bearing-NF-F12-iPPC-2000-PWM/dp/B00KFCR5BA
I have the 1500 rpm version (~53cfm, 0.05 amps)of that fan. It is very quiet and has been on my compressor fridge for 4+ years and works better than the original 72cfm fan.
BIgger fans are generally quieter for the amount of air moved.
High RPM fans are good for higher static pressure ratings, meaning they push air through and around obstacles better.
Noctua fans have high static pressure ratings considering their quietness and generally lower cfm ratings.
My favorite computer fans are from Delta, Noctua, Silverstone and Vantec. I've worn out a few Silverstone fans over the last decade, some have failed due to circuit board corrosion due to a salt air environment.
I will be getting Noctua Industrial fans from here on out and controlling their speed via PWM signal by the fourth wire as I feel they are top dog in static pressure, cfm, noise, and electrical consumption.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
