Joe417
Apr 16, 2017Explorer
If you are mechanically and electrically handy, yes you can, depending on the AC you have.
My AC fan started making a lot of noise and stopped turning. Pulled the motor out and found the bronze bushings were riveted in. I carefully remove the armature from each half of the motor housing and found they weren't worn out just dry of grease. I drilled the rivets out, polished the shafts, heat greased the bushings, and reassembled with screws.
Still running well after maybe a year and a half.
If the bushings are worn you may not be able to find replacements.
You can always replace the fan motor. Most are sold on ebay.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
