Grey_Mountain's avatar
Aug 26, 2018
Non-Frozen Food Items in Freezer Compartment
Please refresh my aging memory cells as to the proper way to start and operate my refrigerator.
1. Turn the unit on at least one day before planned use.
2. Freezer unit will cool down first, then the other compartment.
3. If possile, food to be placed in the freezer should alredy be frozen if possible.
4. Food in the other compartment should already be cooled down if possible.
This does not seem possible or feasible. I can see that ideally foods should be frozen already or cooled down already.
What am I missing except I'm not as smart as I used to be.
Could be that I wasn't very smart to start with too...
GM
  • I turn mine on for at least a few hours befor loading. As you say, load with frozen and cooled items from home fridge when possible. It is just another fridge so you can load it how you like.
  • Your thought process is OK. The reason you put frozen items in and chilled items in is to NOT make the refer work longer and harder to keep things cold. BOTH the freezer and lower chill at the SAME time. It is just the freezer will get to below 10 degrees faster than the lower section, because that is the FIRST coldest section of the cooling unit. Remember, COLD is the absence of HEAT. The refer removes HEAT from the items, hence cold items result. Doug
  • Your list looks good to me, only addition would be to set the temperature control to coldest possible.
    If it's been a while since using the fridge you could check the flu for blockage, such as a wasp, bird or mouse nest.
    Some report using LP mode provides greater cooling.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
