otrfun wrote:
My two cents . . .
If successfully starting/running an RV a/c unit (**), low price, above-average reliability, and proven warranty support, are a priority, the Champion 75531i 3100/2800 watt inverter generator (similar to 75537i except does not have remote start) is definitely worth serious consideration.
IMO, in the field of low-cost, Made in China inverter generators, the Champion 75531i is in a class by itself. It's the only MIC inverter generator that has established a record of reliability, performance, AND excellent warranty support.
** The Champion 75531i inverter generator is capable of producing significant amounts of inrush current---more than two, paralleled EU2000i's or single EU3000iS.
I've read a few reviews from RV users and they all say it will run their A/C no problem, won't run A/C and microwave together but neither will my 5500 ONAN as the entire coach runs off a single 30 amp breaker, so 30 amps is the key I guess except I have no problem when hooked up.
I wonder why they don't run the A/C off the second unused leg on the 5500? Probably because it would require some crafty wiring and isolation, etc. (might be a future project there!).
My purpose for going this direction is multiple, backup for home, occasionally need a generator for work so company can purchase it. And we use generators for race setup/operations once a year at our G.P. Also should my Onan take a dump I'd pull it and go this route, last major repair was over $1,000.00. The wireless remote is really what makes this doable IMHO.
