rundogdave wrote:
17.75vdc between the 2 connections at the bottom right, 1 marked Gnd, the other marked 12vdc. Grounded the pin to the metal backing on the fridge for 2 minutes, with the unit on and the code flashing. No change. I have not been observing the light WHILE I am grounding the pin to see if there are any changes during the process, just after.
WHERE are you getting the DC supply from? That voltage should NOT be higher than 13.8 volts. The 17.75 is your problem. This is a 12 volt appliance you have. Doug
