rundogdave's avatar
rundogdave
Nor cold n811 codes
Help!! I replaced the cooling unit in our 2008 norcold refrigerator due to a leak. Plugged her in and...another code. Green light flashing 5 times, I believe. (It was a few weeks ago) Did some trouble shooting and replaced the circuit board. Just plugged it in, and...another code. Green light flashing 6 times now. I can't find, or remember what web site I went to for the last trouble shooting I did. Not sure I would trust it anyway. I do not have the gas re-connected yet. Suppose I should do that, but I didn't want to complete the reinstallation of the refrigerator, in case I had to remove it for additional repairs. Any help would be greatly appreciated.
  • There is no 6X code.
    ON LED Flashing
    5X is no cooling detected by controls (ventilation or board needs reset ----same as a 'no co' fault)
    4X is controls failure (replace board)
    3X is AC heater failure (element bad or board)
    2X is Mode switch failure (replace optical control assembly)
    1X is Backup system operation (thermistor disconnected or failed)
    ON LED on & GAS LED Flashing
    1X is Gas Lock-out (Ignition/flame failure)
    ON LED & GAS LED both flashing
    1X is IF in 'Auto' no AC Power OR LP gas available
    1X is IF in GAS Mode......no ignition
    ON LED Off
    Fridge turned off
    NO 12V DC
    DC Fuse blown
  • You wasted money. 5 flashes means that it still has the lock out code from when your cooling unit failed. That means the refer tried to cool down twice and each time it could NOT due to the bad cooling unit and it locked out the control board. That means you have to do a HARD reset. Now, you purchased a new board, but there is NO 6 flash code I am aware of. The new board would be a Virgin board and not have the lock out code. You have 1 chance to avoid lockout. If the Refer does NOT sense a cool down cycle it will lock oiut and throw the 5 flashes. You then get 1 bite. Turn the refer OFF for 10 seconds, FIND the reason for the lack of cool down, correct it and start again. IF you did NOT correct the 1st fault, then the 2nd try will lock out the control board. So, I suspect you tried twice and you have a 5 flash code not 6. I also suspect you have NOT either installed the New CU correctly or you have some wires not connected correctly. Doug
    Page 21 or 24 depending on how your PC counts the pages.
    http://bryantrv.com/docs2/docs/ncoldnnewnseries.pdf
