mxdad777's avatar
mxdad777
Norcold 1200 series fridge blowing 5 amp AC fuse
I have a 2005 Norcold 1200 series fridge with a 621271 circuit board. When I turn it to AC power the 5 amp glass fuse blows within about 5 to 10 seconds. I checked both heater elements and they ohm out at 59.7 and 59.8 (both within specs). Just for fun, I tried unplugging the ice maker but the fuse still blew. The fridge seems to run fine on LP. Is it time for a new board or is there something else I might be missing? Thanks in advance for any help.
  • I checked both heating elements and neither one show a short. After researching a bit, I kept reading about the Thermistor. I decided to check the ohms on it and there is no reading at all, it's just open. It's currently 60 degrees at my house so from what I've read I should be getting a reading somewhere between 12.1 and 13. So obviously my Thermistor is bad, but could that be what's causing my AC fuse to blow? I could see it blowing a fuse with a closed circuit, but not an open circuit. Any ideas?
  • If it didn't blow the fuse after you removed the element from the circuit, it's the element that's bad.
  • Thanks for the replies. I did try unplugging the heating elements but when I did I received an error code. I don't recall exactly what the error code was, but it was something that made sense that there was a problem with the heating element (they were unplugged). It didn't blow the fuse, but I was thinking that because of the error the unit didn't try to turn on. After reading all of your replies, I'm going to check the elements to ground when I get home after work tonight. I'll let you know what I find.
    Thanks again!
  • The Icemaker has a different 120 connection It is DIRECT and does not go thru the control board. The Fuse blows because one of the heating elements is grounded. Bad Element. Replace BOTH. Doug
  • you ohm checked the heating elements
    but did you unplug them
    and connect the ac power
    good chance they 'leak' current from the element through the ceramic casing to grounded metal flue/chimney
  • Did you try ohms from each heat element lead to exterior shell of element. That would be short to ground causing fuse to blow.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Jul 31, 2025
