Old-Biscuit
Feb 13, 2021Explorer III
Very Little specific info is available for the 2118 model
Both internal fans (freezer/food compartment) get DC+ thru K6 relay on circuit board
P4 10 Pin Connector on lower edge of circuit board
Pin #1 RED DC+ to both fans
Pin #2 Black DC_- from both fans
(pins are numbered right to left)
Doesn't show/mention any controls for fans.....ON when Fridge is ON
But they could cycle with 'heat source' and or door open/close
'L' is the 10 pin connector
Check for DC at #1 & #2 when fans run/don't run
Propane/Electric Element are on/off based on thermistor temp feedback to thermostat (depending on Temp Setting)
Thermistor in food compartment---2nd FIN from right measures the FIN temp which is roughly 10*F LOWER then the compartment air temp
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
