Donebee's avatar
Donebee
Norcold 982IM Fridge Issues
Issues with Norcold 982IM fridge in 1997 Tiffin Allegro. Won't work on AC or LP. Setting to auto, fridge will start on AC, then after 5-10 seconds switches to LP. LP starts, ignites, flames and then quits. Cycles back to AC, fails, back to LP, fails, etc.
When manually setting to AC, fridge will tone, flash and indicate an A4 error.
Checked converter and is working. No loose wires, all fuses tested and working. RV plugged into shore power, outlet has 120vAC, power board has 120vAC. Checked DC at board and is receiving 12vDC.
  • The circuit board is not recognizing 120V AC so it swaps to LP which doesn't light off so it swaps back to AC...repeat/fail
    Unplug AC leads from circuit board (power cord unplugged from AC Outlet)
    Unplug DC leads from circuit board
    Unplug spark/ignition wire from circuit board
    Remove cover on circuit board
    Unplug 5A AC fuse from circuit board (glass fuse)
    Unplug 3A DC fuse from circuit board (auto blade fuse)
    Check connector pins on leads and contacts on circuit board
    With cover off
    Install both fuses
    Plug AC and DC leads back onto board
    Plug AC cord into AC Outlet (verify it has power)
    Test that there is AC Power on both sides of AC fuse and DC Power on both sides of DC Fuse
    Got power both sides of fuses......try to operate fridge in AUTO
    If fridge swaps back/forth then circuit board at fault
  • Can't specifically recall; I'll test that after work and let you know.
  • Thanks for the reply; I already downloaded that specific document and tried all their suggestions, without any success.
  • If you google "Norcold 982 IM fridge service manual" you can download the pdf @ rvrefrideratorrepair.com and troubleshoot using it.
    Did this for a different model and the troubleshoot steps made for an easy repair.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 17, 2025
