Almot
Dec 16, 2022Explorer III
Doug, my freezer will not get to 0F when the outside coils can't cool well, i.e. hot sun on this wall. It will struggle keeping it at 4, cycling almost nonstop. Fridge would fare better, cooling down to 40, but to keep it cycling almost nonstop - in order to achieve near-zero in freezer - I have to set thermostat to Max, and then fridge goes to 32 and below, causing icing of the fins and freezing water in the tray. If I set it to 1 or 2, it will stop cycling when fridge is 44 -46 and freezer 5-6. This is my reality. In the morning I set it to 3-4, as it gets freezer to 0, in the afternoon I set it to Max to get somewhere from 0 to 4.
Yes, better ventilation at the back of the fridge is needed, and possibly fan inside the fridge - to spread the cold air from those 22F fins around so that it would not freeze the food near fins.
About check valve. It's just a plug on the tube, with a small hole so that something (insects?) wouldn't get in. It's tiny, don't see any one-way mechanism. I removed, anyway. It's not the culprit here.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
