VetPartTimer's avatar
VetPartTimer
Norcold Fridge - Freezer cold, fridge not
2.5 year old Norcold N611FLT in a 2016 Class A
Was dry camping all week at the beach, running the fridge on propane, on the last morning I noticed the milk was not as cold as usual.
Drove home, fridge still seemed a little warmer than it should be. Freezer seemed good and cold as usual.
Plugged into electric, checked the next day both fridge and freezer are good and cold.
Switched it back to propane, checked after another day and freezer was good and cold but fridge is not.
I'm level. Was level all week dry camping.
Any ideas on what to check?
  • dougrainer wrote:
    Big Katuna wrote:
    Shouldn’t be rusty yet but clean/ check flame height, clean flue.
    Get infrared thermometer and establish actual temps on elec vs gas.
    You NEVER use a IR thermometer to verify refer or roof AC temps. In a refer you put in a glass of water. After 24 hours you use a digital thermometer to measure the water temp. That tells you the actual cooling of the refer. Doug
    I’m having no luck balancing a glass of water on an ac duct.
  • If it works on 120, but not on LP.
    1. LP pressure is not at 11.5 inches w/c. just 1 inch below will have a drastic affect on cooling.
    2. The burner is dirty. Doug
  • Big Katuna wrote:
    Would it work on electric but not gas if that happened?
    Fans controlled by that thermostat run based on Condenser Fin temps....not on which heat source is being used
    Fans ON...130*F fin temp
    Fans OFF...115*F fin temp
    1A in-line fuse on DC + to thermostat
  • garyemunson wrote:
    The snap disk thermostat on the top coil in back is known to fail and the cooling fans won't come on. Check that.
    No kidding - mine lasted one weekend when it was new.
  • The snap disk thermostat on the top coil in back is known to fail and the cooling fans won't come on. Check that.
  • Cooling unit is functioning hence the cold freezer/food compartment using electric
    Freezer only cold/food compartment not using propane.....that is because the propane is not transferring enough heat to boiler to change liquid ammonia into ENOUGH vapor that can be condensed into cold liquid to absorb heat from freezer AND food compartment
    Propane system pressure...first thing to MEASURE
    Hard to visually check if it is sufficient or not
    11"WC is 0.4psi
    9"WC is 0.32psi
    0.08 psi difference...can't visually see that
    2nd check.....burner flame
    Strong steady and reaching up into open bottom of flue
    (burner slots fully open)
    Then you pull flue baffle/clean it up (soot/rust) and clean flue walls
  • Shouldn’t be rusty yet but clean/ check flame height, clean flue.
  • Try a battery operated fan in the fridge section. Worked for me since 1978.
