Donebee wrote:
dougrainer wrote:
If on AUTO and it started on 120 and tnen errored out and switched to LP, That means the Circuit board did not SEE 120 volts input. OR faulty 120 input
1. Norcold elements rarely fail. You did buy a Norcold Heat Element?
2. Circuit boards rarely fail(you stated it was replaced last year). So, odds are this board is good.
3. Are you POSITIVE you have GOOD 120 volts to the RV?
4. In 40 years as a RV tech, I have never see a Heat Element work for a while and then fail.
5. Plugged into your home. That sometimes means your Home outlet may be the problem. Possible reverse polarity or heavy load by the RV. Is the unit plugged into a regular wall receptacle or do you have a dedicated 30 or 50 amp outlet? Doug
WHY are you fixated on the 120 element? Below is the diag explanation for C6. Says nothing about the 120 element or operation on 120
C6 Fault within refrigerator controls Not owner serviceable; Consult your dealer or a Norcold Service Center
Per Norcold, they have not had the rear control boards in a few years. WHERE did you get your replacement board? Norcold states it must be a Rear control board fault. So, you either have to get someone to repair it(Dinosaur) Or get a Dinosaur replacement board.
1. Yes, purchased Norcold element.
2. Yes, I believe the board is good.
3. Yes, positive.
5. Home outlet is not the problem and no heavy load by RV.
Circuit board was replaced last year (Dinosaur Electronics), who also advised C6 was an AC Heater related issue.
1. Norcold does not state C6 is a Heater issue
2. When you go to an aftermarket part, you cannot rely on the onboard troubleshooting. Dino does not show a Circuit board for your model on their website.
3. Did you replace the Board due to this same issue?
