Donebee's avatar
Donebee
Norcold Fridge Issue - Help!
Norcold 982 fridge issue. Fridge was running on AC, plugged in at home. Checked and found it was running on propane, C6 error. Replaced AC Heater and turned back on, set to auto. Seemed to run fine but after checking several hours later, find that it is again running on propane and displaying C6 error.
Checked internal control information, all appears within specs, except for AC Heater, which shows 1.5 amps, not 2.7 - 2.9 as listed in specs.
Did I get a bad new part?
  • Okay, I turned off the fridge and let it sit overnight. Tested the new, recently replaced AC Heater and it tests at 44 Ohms. I'm thinking about turning the fridge on, waiting for the element to fail, as it seems to run on AC for 30 minutes or so before it fails. and then ohm it out again once it fails. Perhaps it's failing after the element begins to heat?
  • I would check for output from the circuit board. The circuit board is looking for resistance of the element. It is possible that the relay is bad on the board. you could wire up a standard 120 volt lamp socket with lamp and connect to output of the circuit board to simulate.the element. If thelamp does not light up, the circuit could be at fault. 60-100 watt incandescent lamp should be sufficient.
    Measure your replacement element for resistance across the leads. No resistance means it is open and bad.
  • I'm hoping it's a bad element; the last one worked for the five years I've owned the motorhome without any issues.
  • Sounds like the new element burned up. Either you got a bad one, or something is wrong that is burning up elements.
  • Yes, I am aware of that, which is why I replaced the AC Heater with a new part.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
