mtnman1989's avatar
mtnman1989
Norcold Fridge Model N305R not cooling bottom
My 2017 Norcold Fridge Model N305R is not cooling the bottom of the fridge. The freezer is below zero but the bottom of fridge is not getting cold. Same on Electric or LP gas. I have a thermostor that is factor set and not removable. I think I might could pry it loose though. The fridge has worked fine until this past week. Are there any recommendations on how to fix the problem?
  • How did you learn all this fridge info, were you a tech or do like I do and learn from personal experience?
    I am a Master Certified RV technician with 44 years experience. TRUST ME when I tell you the details on how to troubleshoot and measure temp. You call up RVP(Coleman)/Dometic/Norcold and tell them an IR measurement, they will laugh at you. I do NOT know the difference between the 3 model numbers. There IS a difference between the 3 way and 2 way by the letter at the end of the N305. You NEED a LP pressure test. You will be spinning your wheels if it works fine on 120 but you have a problem with the LP without the pressure test. A not scientific way to test your LP regulator is to turn of the refer on LP. Then light the range burners on full. LIGHT the water Heater and furnace. Watch the Range burners. If the flames pulsate or diminish when you run the water heater and furnace your LP regulator is bad and needs replaced. You can also remove the LP burner and remove the orifice and blow it out. Is the refer in a slide room? Doug
  • I figured you were a tech, lucky to have someone like you on the forum!
  • Update:
    I turn the 120 electric off and did the non scientific regulator test, it did fine. I left the fridge on LP gas after the LP regulator test. It has been on LP gas for 5 hours and the fridge temperature increased just 3 degrees from 27 degrees to 30 degrees! I think it is fine, what's your opinion?
  • Wed July 19th 5:30 am 15 hours later and the fridge is 30 degrees, FIXED! I think the compressed air was all it needed.
  • Sunday July 23rd, 4 days later. Turn fridge on LP yesterday and it was 33 degrees this morning, still working!
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
