drillagent's avatar
drillagent
Norcold fridge won't cool
Hi all. I've searched the forum and haven't found anything like my problem. Hopefully someone can help out. I have a Norcold 1210 in a 2012 Montana. Five months ago our freezer had a large amount of ice on the back wall so we defrosted it. We turned it off and used a hair dryer to warm it up. Everything was fine. A month later we moved on to our next destination and the fridge wasn't cooling. Had a technician look at it and he removed a wasp nest off the LP burner. We mostly run on AC because of my fear of a fire. After he looked at it, it seemed to run ok, but I had to run the temp all the way up to 9 for it to cool enough. Ever since, it has worked some and not worked some. For about the past month now, the box temp has stayed at about 52 degrees and the freezer temp at about 32 degrees with some frost on the back, but nothing is freezing. I have tried running it on LP and AC with no change. I also replaced the thermistor with no change. Current outside temps are mid 40's to mid 50's. And I'm parked in an area with no direct sunlight. I know there is at least one fan on the back because I saw it when I took a picture up the back to make sure the air flow wasn't blocked. But I don't know if I've ever heard it come on. I'm at my wits end and tired of losing money to food that spoils. Does anyone have any ideas or is it time to just call a professional?
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 16, 2025
