drillagent's avatar
drillagent
Norcold fridge won't cool
Hi all. I've searched the forum and haven't found anything like my problem. Hopefully someone can help out. I have a Norcold 1210 in a 2012 Montana. Five months ago our freezer had a large amount of ice on the back wall so we defrosted it. We turned it off and used a hair dryer to warm it up. Everything was fine. A month later we moved on to our next destination and the fridge wasn't cooling. Had a technician look at it and he removed a wasp nest off the LP burner. We mostly run on AC because of my fear of a fire. After he looked at it, it seemed to run ok, but I had to run the temp all the way up to 9 for it to cool enough. Ever since, it has worked some and not worked some. For about the past month now, the box temp has stayed at about 52 degrees and the freezer temp at about 32 degrees with some frost on the back, but nothing is freezing. I have tried running it on LP and AC with no change. I also replaced the thermistor with no change. Current outside temps are mid 40's to mid 50's. And I'm parked in an area with no direct sunlight. I know there is at least one fan on the back because I saw it when I took a picture up the back to make sure the air flow wasn't blocked. But I don't know if I've ever heard it come on. I'm at my wits end and tired of losing money to food that spoils. Does anyone have any ideas or is it time to just call a professional?
  • you can try the above test
    you can also try running it propane for at least 12hrs
    but it is possible you damaged the fridge
    if you always run on 120v and never on propane
    you might consider replacing it with a residential 12ov compressor fridge ( if this one has failed )
    what do you do when traveling, or is this set up in a fixed location
    for seasonal use ? ( in this case ,residential replacement makes good sense )
  • wnjj's avatar
    wnjj
    Explorer II
    ScottG wrote:
    No matter what else, a lousy install will result in lousy cooling.
    That’s true but in a 2012 unit it’s probably been working until recently.
  • No matter what else, a lousy install will result in lousy cooling.
  • Here is what you need to do for TEST of Cooling Unit
    Unplug the electric heater element leads from the lower circuit bd.
    Check that BOTH elements are good.....64 ohms each
    Plug the leads DIRECTLY into the 120V AC Outlet (unplug fridge power cord and plug the leads into the outlet)---4 leads. 2 Black & 2 Yellow
    Connect the 2 blacks together and the 2 yellows together....1 set of black into one of the slots on the 120V AC Outlet & 1 set of yellow into other slot on the 120V AC Outlet
    Turn fridge ON---and let it run at least 12 hrs
    Then measure temps in freezer/food compartment
    Freezer should be 10*F or lower and Food compartment should be 40*F or lower IF cooling unit is functioning
    If NOT....cooling unit is NOT capable of cooling and will need replaced
    IF it does cool down then you have an issue with circuit bd, thermistor,
  • I know most people don't want to hear this but I would look at installation instructions and double check the clearances to the back wall and make sure the roof vent has a sloping "chimney" to it.
    Rarely, if ever do RV manufacuters follow all the guide lines, especially the chimney part. Not doing so can severly effect cooling of a perfectly good fridge.
    Unfortunately the 1210 has limited cooling power to start with so these guidelines are even more important.
    The sensor for the fans don't last long either. Mine lasted exactly one week on a brand new fridge. The replacement part has held up so far.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 13, 2025
