dclark1946's avatar
dclark1946
Norcold moisture reduction heater switch
Just completed our initial checkout of our new KZ Spree 263 RKS on a two day campout. I have been going through all the manuals and was specifically looking for location of the fridge moisture reduction heater switch. The manual for this N811 F mentions the heater but nothing about a switch to disable it like our previous Norcold on our 2007 Spree. Anyone know how to disable the heater to reduce power consumption?
Also this fridge appears to have the optional fan that I can hear come on periodically. The schematic shows a temp switch in series so I am assuming this operates when the outside temp goes above a certain set point.
  • SoundGuy wrote:
    Old-Biscuit wrote:
    Norcold did away with on/off switch for the door flap heater.
    Must be a conspiracy :W ... schematics for my own Dometic DM2652 indicate the fridge clearly has a climate control circuit and a switch on the eyebrow to turn it on/off but no way, no how does my particular fridge have that switch so I added my own switch. If the OP's Norcold likewise lacks a switch I'd imagine the same mod could be done with it as well.
    That is what I have in mind if it looks like power consumption is excessive when we are dry camping.
    Where did you locate your switch?
  • dclark1946 wrote:
    I guess the condenser fin temp will be somewhat dependent on the outside ambient temp?
    Any idea how much current the door flap heater draws?
    Flap heater.........0.25A
    Fan.................0.36A
    Condenser fin temp.....
    Fan ON >130*F
    Fan OFF <115*F
    But heater only operates when fridge is ON :S
    Fan is controlled by snap-disc t-stat attached to condenser fin and closes/opens based on condenser fin temp ---not ambient air temps
  • Norcold did away with on/off switch for the door flap heater.
