gabemcg's avatar
gabemcg
Norcold N300.3 inconsistent propane functionality...
I've spent the last day reading through old topics here but wanted to get some fresh help if possible...
New to me Six-Pax D650 w/ a Nordcold N300.3.
When I first started using the camper, the fridge would light and work for a short while, but as soon as I would turn on the stove or furnace, the fridge would go out.
Pulled propane tank and noticed the output hose from the regulator to the camper supply line was kinked. Straightened this out and now can run both stove burners, furnace, hot water heater, and fridge all at once with no issue. All original regulator and hoses from original build which I think was 2006?
On to the fridge problem... it lights... it runs... but randomly turns off... sometimes after a few minutes, sometimes after an hour.. not sure I've got it to run longer than a few hours.
I am not entirely sure, but I think when I first start the fridge, it is below the temp cutoff point so it starts up running. Maybe it hits the cutoff temp based on the 1-5 setting I have it on and it turns off but the pilot doesn't stay lit? Is that feasible?
I've cleaned things and all looks ok.
Where should I start?
