USMA_Dad's avatar
USMA_Dad
Norcold n811 refridgerator not working
I have a Norcold n811 refridgerator and it suddenly stopped functioning. After my troubleshooting attempts I'm at a loss. The thermistor is functioning, the heating unit gets hot, the condenser fins at the top are hot to the touch, but the absorber tubes are not warm to the touch. I replaced the control panel and that did not make a difference. I have power to it and it works on ac and gas. No fault codes are being displayed. The 5a fuse on the control board was blown so obviously I replaced that. The fridge is mounted in a slide out and unfortunately the cooling fans are dead center in the back of the refridgerator and not accessible. I've been full-timing in the rig and never had a problem. The only thing I can think of is there's a blockage somewhere between the condenser fins and the absorber tubes. I tried wrapping on the tubes but nothing worked. .
Given the holiday weekend I can't get someone out here to diagnose so I welcome all suggestions and advice. Thanks in advance!
  • If you don't have the service manual (google and download it) that has step by step for troubleshooting (you'll need a multimeter) that will eliminate any doubts of eyebrow board/ power board, thermistor, heating elements.
    I just went through this with my N821 same thing no faults except for a '0' on the eyebrow display. No where could I find what it meant but after a bunch of internet searching found it was for the high temperature limit switch (on the exhaust tube) locked out the controls to turn the fridge on propane or electric. Disconnecting the 2 wires from the limit switch and used a jumper to bypass it, the fridge would turn on and run. *Do not run fridge like this it's a safety feature to shut down before a possible fire*. Waiting for new switch to arrive.
    After pulling fridge out of cubby the heat shield that goes over the exhaust pipe slide down and started to block the tube.
  • Jim@HiTek wrote:
    Any ammonia smell from inside the freezer/refer? Any yellow residue on the tubes?
    None whatsoever. No evidence of a leak anywhere.
    I also bypassed the high end sensor (or whatever it's called) to see if that was kicking off the system and it made no difference.
  • None whatsoever. No evidence of a leak anywhere.
  • Any ammonia smell from inside the freezer/refer? Any yellow residue on the tubes?
